Fuel tank, pump, cell?
breakneck88
Member
Feb 5, 2011
8
OK, here it is. I have an '87 MCSS. Getting a 425 hp 383. Eventually turbo/SC. Looking for 450-500 at the wheels. I purchased a jegs 130 gph electric pump. The original plan was to make a bracket and bolt it to the spare tire well behind the axle. Jegs tech said it won't work if I use the stock sender. So, if they are right I need a sump or a cell. Problem is I ran out of $ for the swap. What's the most cost effective way to make this reliable?? Will it work mounted to the spare tire well? I will be running new 3/8 line and maybe use the 5/16 vent for a return.. Really don't know which way to go. If I need a cell is there a bolt in that uses the gm sending unit? Any help or experience is greatly appreciated. Oh and the block isn't folly drilled for a mechanical pump. Last 1/4" is still there. Vortec 4 bolt block. Eventually looking at maybe 8# of boost. Would like to do this once if financially possible. I have to get this done as it is my DD and the 305 is half dead. Thanks.
prairiehotrodder
1,576
4
Melfort Saskatchewan Canada
sump the stock tank. Cap the fuel outlet on top and leave the fuel gage sending unit hooked up. Run 1/2" aluminum fuel line form the sump to the filter and join the filter to the pump with a piece of steel 3/8" threaded pipe about 3" long. Then run 1/2" aluminum line up to your regulator mounted on the inner fender well. I have this system feeding a 600 hp BBC along with a 200 shot of nitrous using a single holley black pump. But i do have a y-block before the regulater feeding a seperate reg for the nitrous system. It works good. If you must run a return line then weld a bung into the top front edge of the tank. A 3/8 line should do fine for a return. GET THE SUMP DONE BY SOMEONE WHO KNOWS WHAT THEY ARE DOING!
brian
bracketchev1221
1,111
Mountville Pa
I agree, sump the stock tank. Most electric pumps are considerd "pusher" style pumps meaning they need to be gravity fed to work right. Some pumps can work as a puller, which would be off the stock sender and create enough vacuum to pull gas out of the tank.
