G Body Elcamino Roll cage help Needed
rwolf15241
47
Pittsburgh, PA 15241
Looking to install a Jegs 6 point roll cage, to stiffen the frame.
1. Box & notch frame .
2. Front Roll Bars, Jegs Pro Touring follows seat height
3. Jegs Main Bar
4. Rear Bars mounting into the storage area.
5. Planning to weld 6 stubs off the frame to pass through the body and bolt to the roll cage.
What do you guys think???
hcky4life08
27
Dayton ohio
I welded mine straight to te frame didn't need to weld tabs of the frame unless you have other ideas or thoughts for doing it
I may be wrong, but I don't think a bolt in cage of your design will pass tech. With "normal" bolt in cages, you have to have a 6" plate above and below the floor of each mounting point. The plate on the inside of the car is welded to the cage. (4) 3/8" bolts through the top plate, floor and bottom plate secure the whole "sandwich".
rwolf15241
47
Not looking to drag race it !!!, just to stiffen the chassis. I don't think it will work any way!!! I'm 6'2 and will bang my head off the bar getting in and out!!
