G-body liquid intercooler kit
DB
363
Alabama
PT1800 built to mount under the dash. 5 gallon water tank with a 500gph pump. BMR aluminum block off plate with 4" aluminum tubing welded so the whole assembly becomes part of the firewall when bolted in. V-band connections on the intercooler and includes Turbonetics Godzilla blow off valve. Supports 1800hp with temps under 100 degrees.
$1500
DB
363
Alabama
Something that needs a PT3000 :D
I'm moving the intercooler to the trunk so I can get the weight back. Off comes the radiator and the factory rear bumper. Hoping to loose 150#.
94mm or 114mm in the grill depending on what I need.
