Grand national rear in a 1979 malibu
pat1979 malibu
27
Mount Ephraim,NJ
Hey guys, does anyone know if a 87 grand national rear is a direct bolt in on a 79 malibu? Someone said i may have to shorten the drive shaft an inch? Thanks for ths help!
1981Regal
1,274
Cincinnati, Ohio
Yes it will fit, you'll also need to shorten the driveshaft 1 inch. The 8.5 pinion length is longer vs the 7.5
StreetBu
4,158
3
Upstate NY
Yep, have one in mine, direct bolt in except the driveshaft needs to be 1" shorter as 81Regal said. I even swapped the whole backing plates and brakes from my 7.5" right over too.
MISFITmalibu63
7,163
The Sticks... Tewksbury MA
its a direct swap, except the driveshaft has to be 1" shorter. if you can get the driveshaft from the donor car, that should be 1" shorter. that's what I did for the 8.5" that was in my 2 door before the dana 60, and also what I did for my station wagon.
