So Im about ready to get the car back on the road and Im having some issues with this tach. The instructions say to hook it all up and turn the key on but dont start, then use the dial to set the shift light. They say that after this the tach will remember the shift point and work fine. I hooked the power wire to a switch real quick because Im having some ignition switch issues. I turned the switch on and set the shift point, then turned it off. Turned it back on and started the car, but the tach wont read, it keeps going into shift set mode. Any ideas on how to fix this?
