how much paint?
rodneypierce
473
Cedar Rapids, IA
Hey guys, im getting ready to paint the Malibu here soon, and was curious as to how much paint will be needed for the entire car and engine compartment (bumpers and grill included). Ive heard a gallon once reduced will be plenty, then have also heard that I should buy 2 gallons. Also, same for clear.
Just trying to get an idea here. Color will be silver metallic over gray sealer, so coverage should be pretty good I would think!
melloelky
3,590
mass
one gallon will reduce to make two sprayable gallons.don't buy two gallons you'll end up with four total gallons.it's not cheap,save your money&yes with the grey sealer it will cover well enough
melloelky
3,590
mass
it depends,are you gonna lay down 2-3 coats and be done or are you gonna block it out and clear it again?i know you said the firewall grille etc but I'd go with over a gallon.if you end up having to respraying the car or some stuff and end up flow coating the car or some parts your looking at more than a gallon..if moneys tight you could start out with a gallon and two quarts and see how much your using as you go along with the painting.it really depends on how you paint and what your looking for it to look like. you might find yourself using more material than you thought.i'd rather see some left than not enough.
1 Can there be too much ARB? Suspension Technical 4
78_Landau How much is too much to pay 442 10 bolt? Drivetrain Technical 15
D how much is it worth Drivetrain Technical 2
D How much is this Malibu worth???'s Drivetrain Technical 10
D Will this cause to much cam lift ???'s Drivetrain Technical 13
W How much will 10 bolt rear take Drivetrain Technical 6
C will anti roll bar help much with a 60ft time Suspension Technical 9
daveybtv 7.5 posi how much gear oil? Drivetrain Technical 6
Z HOW MUCH OF A DROP CAN I GO?? Suspension Technical 8
lsbw17 correct fuel pressure for 396. bbc 7 1/2 to much? Power Adders 5
Firetruck1 Flat hoods, How much motor can you fit? Drivetrain Technical 7
RKRUZEN how much Friction modifier should be used??? Drivetrain Technical 2
D How much is this SBC shortblock worth? Drivetrain Technical 3
D How much is this crankshaft worth????'s Drivetrain Technical 2
B how much nos for ls block. LSx Tech 10
BillySS Trying Hydroboost, much needed advice PLEASE Wheels/Tires/Brakes Technical 14
Q lowered a bit much.... now what? Suspension Technical 15
8 Why So Much timing?.... Need Help. Drivetrain Technical 16
slpfeife9651 how much rear differential fluid? Drivetrain Technical 2
B How much fuel pump for 700HP? Drivetrain Technical 4
V a little to much rpm? Drivetrain Technical 4
Malibu 361 How much power can a 8.5 Grand National rear handle.... Drivetrain Technical 4
jaywill how much power will a 7.5 ?? Drivetrain Technical 25
C How much lift will stock LS springs take? LSx Tech 2
C How much lift will stock LS springs take? LSx Tech 1
Apathy93Z 2000 too much? LSx Tech 4
D How much did you spend on your LS swap? LSx Tech 6
LT1_Malibu 2" drop spindles too much? Suspension Technical 7
E how much nitrous Power Adders 16
Malibu 361 How much HP can 33 spline axles support,....? Drivetrain Technical 15
Steed How much power for a stock 8.5? Suspension Technical 5
87Aero How much lift for Vortec 906 heads?? Drivetrain Technical 7
3 do i have to much carb? Drivetrain Technical 13
4 100 octane how much nitrous low comp bbc Power Adders 1
4 2 holley red pumps how much hp can they support Power Adders 2
D How much is this engine and trans combo worth? LSx Tech 7
3 How much $$ for 100 hp jet Power Adders 5
T How much power from a 6.0? LSx Tech 7
Blackwizard22 How much nitrous? Drivetrain Technical 8
8 how much air bag pressure do you run? Suspension Technical 3
G How much improvement? Drivetrain Technical 2
B How much power can the TH350 take? Transmission Technical 1
johnnycarlo How much ET loss going from a TH350 to TH400? Transmission Technical 5
A How much fluid?? Transmission Technical 4
Brian79 Is a 4500 stall to much Transmission Technical 9
Killermalibu would it matter much? Wheels/Tires/Brakes Technical 9
eldabo 3.5 in front rim rolls the side wall to much Wheels/Tires/Brakes Technical 3
Flat Black Wagon How much air pressure for a 33x17 slick? Wheels/Tires/Brakes Technical 4
Z to much juice (not a bu) Electrical/Wiring Technical 1
prostreet66 Fresh paint chip repairs Autobody/Paint Technical 3
Similar threads
