how to identify motor size 4.8-5.3
G-BUDDY
Member
Jan 20, 2011
8
so i found a great motor for very cheap the prob is the guy doesnt know if its a 4.8 or 5.3 so my question is how do i identify the eng size? is there a website with this info? should there be a stamp on the back of the block ? i want to pick it up 2mrw for sure but just want to make sure on the size thanks for all the help ....this site ROCKS \:D/
LT1_Malibu
202
Greenup, Kentucky
From what I read on the interwebs the info is stamped on the head gasket tab that's exposed. It should say either 4.8 or 5.3.
z28krazy
150
New Braunfels, Texas
Supposedly, these engines have the metric displacement (4.8L, 5.3L, 6.0L) cast on the passenger side rear of the block. Some also have the size cast on the side of the block near the freeze plugs. I've never looked at one, so take that for what it's worth.
If you look at the pad on the passenger side of the block, you might even find part of the vehicle VIN ID there. The older gen SBs had a three letter code that told you what year it was and what it was used for, unless it was an over the counter dealer replacement engine. Don't know if that's the case with the new gen blocks.
boostinmalibu
756
joplin missouri
If you can't find any info on the numbers and such, pretty much the only other way is to pull a head. 4.8s had flat tops and 5.3s had dished pistons. I'd buy it at 4.8 price just to cover your *ss though.
Tig
30
NC
Should be casted in either 4.8 or 5.3 like z28 said "on the passenger side rear of the block"
v8power
511
okc
boostinmalibu said:
The 4.8s and 5.3s shared the same block, only difference is the stroke and piston.
Right it will say 4.8/5.3 on the block. Only way is to pull a head, or get a bore scope down there
D&A Machine Shop
Crank and rods are the difference. Even if its a 4.8 you can make a 5.3 by changing the crank and rods, or you can make a 5.7 by boring it and changing crank rods and pistons, you could go as big as 383 with the 4in stroker kit and the 5.7 bore.
If you are looking for a core to build then it will be an easy base to start with.
