ill fitting lower radiator hose
melloelky
3,654
31
mass
the new stock lower radiator hose doesn't fit the new griffin radiator by a 1/4". the stock hose measures 1-1/2id and the inlet of the radiator is 1-3/4od.has anyone run into something like this with an aftermarket radiator? :-k thanks.
shvrolay
No, but I've used WD-40 on stubborn hoses...........works well.
bustedknuckle
959
St. Louis-Missouri
The griffin rad i bought was the same way, i used dish soap and forced it on. No splits or cracks yet, been on there for 2 years now.
melloelky
3,654
31
mass
man if i got this hose on @a 1/4" to small might not need a clamp! ;)
I've spoken to Griffin about that a few times. They say it's because it's a stock replacement fit radiator. I tried to tell them the stock hose isn't 1-3/4". Their answer was "just call us when you order your radiator, we'll make it for you with the 1-1/2" fitting". I think they missed my point...
melloelky
3,654
31
mass
](*,) i work with aftermarket parts everyday and they're cheap junk but the hoses fit,i never expected this from a company like griffin.they didn't miss your point, they just don't care.stock replacement?i think not.
The funny thing is, their website states "Some models may require 1.75" lower hose". I may very easily be wrong, but I don't recall any OEM G-body application that uses an 1-3/4" lower hose...
melloelky
3,654
31
mass
godforbid they provide a part#or a source to remedy a problem to go along with a product they make ](*,) ](*,) ](*,)
melloelky
3,654
31
mass
thanks bustedknuckle,the soap/heat gun/gloves/hook tool and foul language did the trick.i can't imagine changing that hose on the side of the road. ](*,) ](*,)
