Hey everyone. I installed rally gauges w tach into my car that was a sweep idiot light cluster.Everything works fine but the tach. I have the lead from the tach from the pin connector hooked up to the tach output of the msd 6al box. At a idle it seems to read fine. at 3000 rpm the tach reads 5000. The tach is out of a v 8 car. Called msd told me to install a tach adapter. I did w no change. then they said to run a diode inbetween the tach out put of the box and the tach adapt I did No change. Thinkin it might be the tach itself i swaped anothe stock v8 tach in. No change. Im at the end of my rope. Ne1 have some advice? Any help would be greatly appreciated. Thanks, Mike.
