In the cowl hood market...
RATFINK!!!
31
Franklin, OH.
www.facebook.com
I knew it was going to happen and it did. After sitting the BBC in the Malibu the stock flat hood will not shut. I am now in the market for a 2" or 2 1/2" cowl hood. It must be a bolt on unit as I am trying to keep this thing looking factory. I would like it to be a steel hood, but that is not set in stone as long as the glass unit looks and fits GOOD. Don't want to have to spend a week doing body work and getting it to fit.
Question, Who has a KICKIN cowl hood that you would recommend?
TIA, Don
RATFINK!!!
31
Franklin, OH.
www.facebook.com
t5montecarlo said:
There are others with a BBC and flat hood. Perhaps your intake is just too high. You may have to compromise between stock looking and intake height.
I run a Performer RPM Airgap intake which is the same height as a Performer RPM so it looks like I'm going to have to use a 2" cowl hood which is not a huge deal as long as I don't have to run a 4 or 5 inch hood.
zapc
14
I have a bbc in my 84 elcamino with an rpm airgap manifold if u use a proform drop base aircleaner it just fits under stock hood, and i mean just barely fits, but its how i run mine
It should fit wiht a stock BBC drop base open element air cleaner, too. My choice for a steel hood would be Goodmark. GM resto parts approved.
RATFINK!!!
31
Franklin, OH.
www.facebook.com
It's not going to fit. The hood won't close with just a 2" carb. stud in the carb. I just ordered a AMD steel bolt on unit. $523 to my door. Goodmark seems to be hit and miss on fitment, AMD appears to have no complaints on quality or fit. Now I need to take it down to my Painter on Retainer and have some 97 Lexus Brandywine shot on it, and bolt it on. Thanks everyone for the advice.
Just read a LOT of "Goodmark vs. AMD" stuff & it looks to me like the general line of thought is that AMD is better sheetmetal. I spoke to Mike Gray @ AMD. He says they have their own tooling, but the stuff is stamped out of coutnry. No one at Goodmark would tell me whose tooling is used...
I guess I'll be going with AMD when I get my hood!
RATFINK!!!
31
Franklin, OH.
www.facebook.com
I spoke to a lot of people running both, and they all stated that Goodmarks quality has fallen way off. I had an issue with AMD stamping their products off shore and I let them know the same when I spoke to them, but in the end I want the best product availible for my rig, and it appears that AMD is just that.
JBreu
321
Livonia. New York
I have the goodmark 2" steel bolt on from a Goodmark dealer in my area for $450.00 and love the looks of it!!
