The motor mounts,, I went to get a 85 cu ft bottle of gas to weld with and they gave me a empty bottle,,so note to welders out there,, check the valve before you leave the shop,,, ](*,)
Here ^^is the view from the bottom looking up at the bottom of the 1/4 plate the rubber mount will be bolted to, this is just a mock up,, I was going to box it in but I found a 1 5/8 dom tube that I am going to weld to the frame horizontal and put the angle to match the bottom of the motor mount plate with some 1/8 gussets on the sides of the 1/4 plate down to the frame as well for additional support,,
