line lock and manual front disc brakes
KingLevi
51
Louisville, KY
Guys anyone ever had a problem with locking up manual front disc while doing burnout at track? Put a new biondo LL ( thought the old one was bad) on and bled the brakes couple of times. during burnout i pump it up 3 times and hold ,flip the switch , it holds but once the tires start to spin the car starts pushing though. any ideas?
combo 500 hp 406 - 488 gear - mt 275dr - th350 - 70 corvette manual master cyl. ( four wheel disc ) combo valve and brakes off third gen camaro
best 60' 1.68 spinning think i need to warm tires
Thanks for the advice and info
Are the front tires locked but sliding, or are the front brakes not holding? If the front tires are locked & sliding, it's not the LL. You need wider front tires.
Robert1320
X2 Or more aggressive burnout technique to prevent pushing the tires.
purple barney
576
Raleigh NC
i stab the throttle hard then let off. it took me a while to figure that out if you hold the line and start slow sometimes it will push the front out.
