A Non-Lock is much better for engines with large Cams. Lockup's can transmitt a lot of engine firing pulses with long Duration Cams, jerky feeling.
Non-Lock TC's are much more efficient up top than Lockup's when not locked.
To do WOT shifts with the TCC locked requires a multi-Disc TCC clutch, 5-7 Disc, $$$.
There's only about 150-200rpm difference between Non-Lock & Lockup TC when cruising.
Non-Locks do produce more heat but, a good Cooler will take care of that.
IMHO, Non-Locks are much better for Hi-performance use. Lockups for mild Perf, MPG & cruising.
Todd
