looking for a converter, 200-4r
MISFITmalibu63
7,163
The Sticks... Tewksbury MA
i have a BRF code 200-4rr4 from an 87 GN to go into my wagon, the engine is a 355 with a healthy cam (no idea, its in my Dads engine). i know he needs a vacuum can to run his brakes.
looking for converters, all the ones i see advertised are for 82-84 only. are there special ones for 85-87?
as for a converter, this will see 95% street time and 5% track time. so something a little higher over stock is what im looking for.
this is what i was thinking of:
http://www.summitracing.com/parts/BMM-70415/
1982 - 1987 200-4R torque converters interchange without any issues. The '82 - '84 notation really only applies to the 700R-4 transmission as the '82 - '84 model years feature a 27-spline input shaft which allows 700R-4 and 200-4R converters to interchange in those model years.
What rear gear ratio are you running in your wagon? How much vacuum does the engine pull when idling in gear?
MISFITmalibu63
7,163
im running a 3.42 rear, also an 8.5" from an 87 GN. as for the vacuum, i don't have a gauge, but i can pick one up and find out.
4,659
31
Be sure the converter has a lock-up clutch inside.
My MCSS stock would rev to roughly 2300-2400 on the foot brake. I have to wonder if 2400 stall would be any different than the GN converter?
MISFITmalibu63
7,163
Just checked it. Idling in park, it's 12-13" and idling in gear is 10.5-11". Keep in mind, this is with a 30 year old gauge from my grandfathers garage.
