I bought an angle finder and some double adjustable uppers in an attempt to get rid of a vibration that happens around 70mph. I've tried all kinds of different angles from +3 to -5 (positive = nose up, negative = nose down) with some helping and some making it worse. The stock arms had the angle at +4, which caused horrible vibrations and grenaded my old transmission and driveshaft.
The best place seems to be between +1 and -1, but the vibration is still there. I tried many stops in between, with no luck at all.
It can't be tires since they vibration becomes far worse upon coasting, and almost turns into a grinding feel.
The trans is good, motor mounts good, transmission mount good, and drirveshaft new and balanced.
Not that this is the culprit, but there was no problem before having Richmond 410s put in.
Does this all point to a shitty balance job on the DS?
