MANUAL OR POWER BRAKES
MYMONTECARLO
50
CINCINNATI,OHIO
I just installed disc conversion kit on my car. I need to replace factory mc. I have factory power brake set-up w/ elect. vaccum pump to brake booster due to big cam not suppling vaccum to booster. Now that i have installed disc in rear,should i stay w/power brakes or switch to manual ?? strip and street car.. what mc would you recommend if running manual?? If power can i replace w/factory set-up or w/disc now in rear do i need a aftermarket mc to supply enough pressure to rear disc, i will be installing wildwood proportioning valve to control pressure.. thanks again for suggestions.
MYMONTECARLO
50
CINCINNATI,OHIO
Well, i decided to switch to manual. i just order kit for manual brakes from steel concepts. Everyone on the website is said good things,i'll install and reply. Only thing i've read about on here, guys say you should run 1' bore size for mc to achieve the best feel for pedal w/manual? Steel concepts are a strange mc w/ 1 1/4 bore size,well see if pedal changes dramactically from power brake set-up..
