MAP for LS1 intake
quickie70
65
Denver, CO
where does it go? I got a bare car intake, and went to swap my truck stuff over and there's not a place to plug it in that I can find. There's the block thing on the back on the intake that may work, but not with my current sensor. any ideas?
388bu
3,228
Huntley, il
www.shiftn6.com
Yeah, its in the back.
I tried snapping off one clip on the truck MAP and making it fit. I stopped quickly and decided to just get the F-body MAP instead. The plug is the same even!
Keep us updated. Im curious how you handle the coolant crossover in the front and your PCV system.
quickie70
65
Denver, CO
pcv will be teed into the brake booster, and I'm not sure what the issue with the front coolant bypass will be Looks like it'll fit right now... do you know something I don't?
Double_Trouble
262
Quad Cities, Iowa
i just got a z06 cross over tube. its fatory blocked in the back passages and one tube that goes from one head to the other front only.
