moog 5660 or 5662
malibu hyde
car has 2" drop spindles n v6 springs still...rubs on fender lip n bottoms out here n there...been lookin at moog spring chart, so moog 5660 or 5662 ??
dyrt
45
yardville, nj
Howdy,
Let me tell you my experience. I have a 1986 regal with an lt1 with iron heads and a 6 speed. The car has the a/c system in place, power brakes, power steering. I did the ls1 brake swap which added 3/8" each side to the front tire width. I installed 5662 in it as well as g-body cargo and the car sits higher than i would like. I removed a third of a coil off the front springs and it is still too high for me all the way around, but i need to keep the car at that height because i run 245/45 17 tires and i will get just the slightest rub on the front fender lip at higher speeds when i hit a bump. To be honest, the 5660 springs are softer and would probably have put me right where i am now without having to cut the 5662 springs i have. You mentioned you still have the v-6 springs, what drivetrain and options are you running on your car? How low it is now, and how high are you trying to raise it?
Mike
Canadian-T-Bone
1,147
Abbotsford,B.C.
I did the 5660 & IMO are way too soft , the front tires 245/45/17 rub alot . I wish I had gone with the 5664 spring like I did in my previous malibu .
dyrt
45
yardville, nj
Were you running 5664s with drop spindles? What kind of brake setup are you running and what offset wheels? Have any pictures of the height you had in the front?
Mike
malibu hyde
im not trying to raise it...just dont want the front to rub...wheels r off 99 s10 205/65/16 (wrong offset ??)...tryed stock 14's on front n still hit pullin in driveway tho...car has 350/350, 2" drop spindles
dyrt
45
yardville, nj
I apologize I thought you meant it was sitting too low and rubbing because of it. If you just want a heavier spring the 5662 will probably do just fine for you. As far as the wheels are concerned, as long as they are zero offset 2wd s-10 wheels you should be fine. as far as i know the 4wd models used a different offset but i might be thinking the offroad models.
Mike
razor376
159
Florence , SC
Does anyone have any ride height measurements & tire size & pics using the 5660 & the 5662 springs cause I'm also torn between springs for a 87 Elcamino small block with a/c , I have 225/70/15 tires up front which is advertised at 27.3 inchs height and with stock springs my front fender lip measures right at 28 1/2 high and I would like to drop it about 1/2 to 1 inch to close the gap up some . I am also considering the Hotchkis 1902F springs that have a advertised 1in drop any feedback welcome . Thanks
