My Pro Touring conversion
Meat Drapes
1,184
Jacksonville, NC
Converting to a Pro Touring stance and I am ready to get started.
Meat Drapes
1,184
Jacksonville, NC
Out with 3.89 gears and in with 3.50. The 9" is pretty easy to build. The pattern was a pain to achieve though.
melloelky
3,590
mass
nice!looks like you're on your way,a little at a time you'll get there.what else is in store for it?
Meat Drapes
1,184
Jacksonville, NC
New seat covers. Headliner. Recover the dash, Painless 24 circuit electrical. Make sure driveline is good.... check clutch( McLeod Street twin) add a new hydraulic throw-out bearing. Needs a new master and run the line better. Stroke the 454 to 489. Get rid of the Merlin heads and add AFR Magnums. Brake upgrade( Blazer) to include all new lines. Fuel injection ( FiTech Mean Street ). Ill think of more. I have most of these parts....some are on the car already and need a little attention and some is going to be new.
This is the last time I do this. It hurts too much to crawl under the car but I think I can build it one more time.
TURNA
6,031
Socialist NY
You iron that door panel better than your Dress Blue's!!!!
Meat Drapes
1,184
Jacksonville, NC
Ha!! I wish I could manage photobucket as well as my ironing prowess. I managed to screw up all of the pics already.
Meat Drapes
1,184
Jacksonville, NC
OK. More stuff done. Managed to get all of the seats out. This is a first. And my biggest surprise was the date on the foam from the back seat. July 30, 1979. Love it!!
Meat Drapes
1,184
Jacksonville, NC
TURNA said:
Oval ports heads?
If so NICE!!!!!!
For a street machine. Oval. The Merlins on the car now are oval. I set the MSD digital 6 box rev limit at 6200. I like the car to make all its grunt down low.
StreetBu
4,162
Upstate NY
Welcome back! Car is looking good!
Meat Drapes
1,184
Jacksonville, NC
Took all of the interior driver side moldings out. Some of them were SO BRITTLE from sun exposure that they were not capable of going back in.I ordered a few new pieces. And I am pretty sure I need to remove the quarter glass to get to the dew sweeps there.
I always wanted to take the mirror off and tighten things up. No more rattle after this.
Meat Drapes
1,184
Jacksonville, NC
New brake lines for the new brake hardware. New braces for the rear. I have SOO MANY parts to hang.
autonaut Pro Touring questions Suspension Technical 3
A Calling Pro-Touring Guys Suspension Technical 5
B pro-touring or pro-street? Wheels/Tires/Brakes Technical 3
M Baseline Suspensions Pro Launch Gold - 12Bolt into G-Body Suspension Technical 7
D Which sparkplugs for SBC Dart Pro 1 Platinum heads???'s Drivetrain Technical 12
B msd pro billet corrosion Electrical/Wiring Technical 5
J Strange pro disc with S10 drop spindles? Wheels/Tires/Brakes Technical 0
U UMI Performance New Product- Pro Style Rear Sway Bar Suspension Technical 0
T AFR 195 vs Dart Pro 1 200 Drivetrain Technical 3
G Iron eagle 215's pro's and con's Drivetrain Technical 5
R Pro Comp heads ? Drivetrain Technical 2
Hooligans Pro Charger VS Vortech Power Adders 12
P Pro-Filer 210 Heads just arrived! Drivetrain Technical 6
454RAT Problem converting to 67 camaro spindle/strange pro brakes. Suspension Technical 1
T Pro Charger? Power Adders 13
Alexander Pypes Race Pro Dual Exhaust System Drivetrain Technical 22
T speed pro hyper pistons Drivetrain Technical 11
79izfine B & M pro ratchet shifter Transmission Technical 3
L new pro flo xt intake LSx Tech 6
B Pro Comp and other BBC aluminum heads Drivetrain Technical 4
6SecondWannabe Centerline Convo Pro question need help!! Wheels/Tires/Brakes Technical 2
fastrat350 Should I DIY or leave it to the pro's? Drivetrain Technical 5
R best way to clean polish and seal backside of weld pro stars Wheels/Tires/Brakes Technical 3
E Hoosier radial slick / weld pro star rims Wheels/Tires/Brakes Technical 0
attngtr Hoosier Quick Time DOT Pro Tire Wheels/Tires/Brakes Technical 5
A Pro Comp fuel level? Electrical/Wiring Technical 0
Excelerater Summit/Jegs Pro Stars Rims Wheels/Tires/Brakes Technical 3
SEVNT 9 Hand brake conversion with center console Wheels/Tires/Brakes Technical 1
L 4-speed conversion Drivetrain Technical 10
S Muncie Conversion 80 Malibu 4 door Transmission Technical 4
V Turbo350 column to floor shifter conversion? Transmission Technical 2
SRD art My coilover conversion work great! Suspension Technical 0
7 headlight conversion, 1980 malibu h4 bulb HELP?? Electrical/Wiring Technical 4
Wagonized Thoughts on doing a rack conversion.. Suspension Technical 6
J 83 wagon 2-door conversion Autobody/Paint Technical 7
79izfine 200r4 /// iceman crossmember and conversion questions Transmission Technical 5
B alternator conversion wiring harness Electrical/Wiring Technical 0
1 Buick V6 TBI conversion V6 Tech 3
madmaxx57 t-5 speedo conversion Transmission Technical 4
starfire350 Ls conversion begins LSx Tech 12
CruizinKev Flynbye Front C5 conversion bracket question Wheels/Tires/Brakes Technical 0
M 5" to 4.75" conversion question Wheels/Tires/Brakes Technical 3
M Manual Brake Conversion with Pictures Wheels/Tires/Brakes Technical 58
Bill in NC How To: Landau to standard B-Pillar conversion with pics Autobody/Paint Technical 36
383malibufiend rear disc conversion questions Wheels/Tires/Brakes Technical 1
W rear disc brake conversion question... Wheels/Tires/Brakes Technical 2
C Manual Brake Conversion Wheels/Tires/Brakes Technical 1
Killerdave8813 T56 Conversion V6 Tech 16
S disc brake conversion on 8.5 rear. Wheels/Tires/Brakes Technical 4
8 94 rear brake conversion? Wheels/Tires/Brakes Technical 14
Similar threads
