Need Advice on Extra Capacity Oil Pan
YAV8
155
Manitiowc, Wisconsin
The marine pans for the one piece seal blocks are a 6qt design and are a little longer in the sump and a drain in the back or bottom. One other thing to get more oil capacity is to use the longer oil filter, one for the one and two ton trucks. I have build several 383s using the one piece seal blocks. I used the windage tray that came on the vortecs blocks and had to mod where the crank came around and just used the stock pan. Never a problem with any of the motors some are street but most are all out drag motors.
