Need help... BAD wheel hop!!
78_Landau
11
So, I have a 78 Malibu I just picked up two weeks ago. Basically stock 350 with a 350 trans and stock rear. I found a 7.5 inch 10 bolt posi rear with 3.73 gears so I bought it and last night put it in. Went out for a ride, it runs awesome but I went to do a burnout with the car (at the request of my 15 year old lol) and man, I thought it was gonna shake the whole car apart I had wheel hop really bad. Now it didnt do this when I had the open rear in the car. The car sits up slightly in the back, the guy I bought it from said he was going for the old school look and he installed I think it was springs from a wagon. Could this be my issue? I did it once more while I had my son watch and he said the tires looked like they were bouncing. Like I said, going down the road normally I have no issues. Not even when I pull out hard. Just when doing a burnout. Any help would be greatly appreciated. Thanks in advance
YAV8
155
Manitiowc, Wisconsin
Saw a monte at the track the other night do the same thing. I found out later the kid had a set of air shocks jacked up tight so he could get a set of tall tires under the wheel wells. Sounds like mabe the same thing with the stiffer springs. Hard to transfer weight with stiff spring or over inflated air shocks.
prairiehotrodder
1,576
4
Melfort Saskatchewan Canada
You need tubular control arms and a rear sway bar. Or do the low buck thing and just put new tubular lowers on and box your uppers with some 14 gage sheet metal. Don't over-tighten the pivot bolts. They have lock nuts.
bracketchev1221
1,111
Mountville Pa
Lower the car down. The rear suspension bars are pointed so far up that it's forcing the tire so hard and fast that the tire and shock can't control it.
78_Landau
11
Thanks for the input fellas, one thing I think I wanna definitely do is get those heavy springs off. And you know what, Prairiehotrodder mentioned a good point. I may have over tightened the pivot bolts. I even saw they were locknuts and not thinking torqued everything tight.
melloelky
3,654
31
mass
78_Landau
11
grizwald
3,300
Ontario, Canada
also, make sure you tighten your control arm bolts with the suspension at ride height.
