NEED HELP DECODING SAGINAW CASTING NUMBERS
LIVE4RDO
678
Staten Island, NY
CAN SOMEONE SHED SOME LIGHT ON WHAT THE HELL DO I HAVE, PLEASE.
El Coolmino
2,505
DSM IA under a green truck
Most likely came behind a 4 cyl originally. The 3 rings in the input shaft indicate it's got the lowest first gear (3.5) of all saginaw 4 speeds. Unless a car was special ordered with a close ratio transmission you can kind of guess the engine it was coupled to, with larger engines getting higher first gear ratios.
My $.02, it's a Saginaw and if you beat on it much you'll likely break it :lol: Imo there isn't much to be gained (other than personal knowledge) from the casting numbers. The main case is probably the same as any other 4-speed Saginaw, I think the only difference came in the tailshaft. Mine has lived so far for the most part (same gear set), but I don't shift it hard or shock it much at all. Somehow a couple of the reverse teeth on the countergear chipped off, and it's not like I race it in reverse or anything. It's definitely no rock crusher.
Word... just like a taller gearset having less teeth, allowing for thicker teeth.
To be honest I did have a day I beat on it a bit during a cruise in Troy, MI, everybody was doing burnouts alongside the curbs when cops weren't around :lol: It seemed to hold up ok, but they were just 1st gear and I didn't have to shock it too hard to break the tires loose. On another note it was over an hour drive each way. I took it down & back, never got the least bit warm, even though at least half of the cruise was stop & go style.
LIVE4RDO
678
Staten Island, NY
What are my chances of selling it?
If you find the right buyer, and if it's in perfect internal shape then it's probably good for $200-$300 tops. I bought mine with the internals in near perfect shape (outside wasn't the prettiest, but overall in real good shape) for something like $125-$150 if I remember right.
El Coolmino
2,505
LOL
I've had a nice looking 3 groove saginaw with indy shifter in my swap meet booth for the last 3 years tagged at 150 and get ten offers per meet of $50, nobody's willing to pay more. If you can get 300 drop me a PM about selling mine on commission :)
