Need help wiring a msd 6al to a adjustable timing control
billetss
130
twin cites
Re: Need help wiring a msd 6al to a adjustable timing contro
sorry the box is a msd universal adjustable timing control pn8782
ScotSea
381
Went over to yahoo, and plugged in "msd universal adjustable timing control 8782"
and got:
http://www.msdignition.com/uploadedFiles/MSDIgnitioncom/Products/RPM_Timing_Controls/8782_instructions.pdf
billetss
130
twin cites
I got the instructions but it doesnt show you how it wires into the 6al only into the coil? so do bought boxs go to the coil?
ScotSea
381
http://www.msdignition.com/forum/archive/index.php?t-6980.html
ScotSea
381
This was the MSD tech's answer for that:
msdtech2008-01-2006, 10:40 AM
The orange wire from the 8782 will connect to the white wire from the 6al. Next connect the red wire from the 8782 to the red wire from the 6al, make sure you ground the 8782 to a good engine or chasis ground. Finally your dist. will know plug into the 8782 . The white wire will not be used, make sure to place a piece of electrical tape on the end so that it does not make contact with anything.
billetss
130
twin cites
Thanks guys but now I upgraded to a digital 6 box so would it still be the same?
