Just finished up with my manual brake conversion on a 86 Monte Ls. Master is out of a Manual brake Malibu. Front calipers are wilwood oversized GM calipers, new pads, and stainless lines. The rear brakes have new shoes, new wheel cylinders, and new stainless line. Master is from Napa, my second one, thinking the first one was bad. Master was bench bled then transfered to the car. Used my power bleeder (air compressor kind) to get the majority of the air out, then went and did all the sides by hand. The pushrod is adjusted so there is roughly 1/4 inch of play in the pedal. I cannot get any pedal on the car what so ever. I have heard Napa masters can be just from the store, but I'm on my second one. The back brakes are adjusted tight. I have another master comming from a different store, different brand. Anyone have suggestion where to go next? I'm starting to run out of options.
I also put the old power master on the car to check pedal. Again NO pedal. I have checked again and again for leaks but to no avail.
Thanks,
Cory
Thanks,
Cory
