Anyone have any information on the timing you need to run on a nos sniper 50-175 shot plate kit for a holley carb. motor info I am running a SB 350 performer rpm intake new heads and a holley carb that im buying from a guy i work with i will get the specs soon and update everyone, stock pistons and bottom end. th350 trans with a 2500 stall and a 373 gear out back. I have been doing alot of reading and trying to figgure out the timing issue because I don't want to blow up my motor just due to the fact the the timing was a few degrees off! also a side note im buying the jegs complete fuel system which is capable of 130 gph and a fuel cell any help would be most appreciated
thanks
Smitty
thanks
Smitty
