Hey guys, in a nutshell, 350, mild rebuild done app 15000m ago, 268 cam, supposed to be forged pistons, stock crank and rods, i bought it a month or so ago, the previous owner had warned me that it uses a bit of oil and he was certain it was valve seals.....i get it home and drive it app 1000m over a month and its down at least 3ltrs of oil!!! On start up there is zero smoke, driving around town, zero smoke, but at high rpm, 4500-6000rpm it has some minor smoke, i swaped intakes and carbs, in that process i left the pcv out and just had breathers installed, that then caused the dipstick to push out and spray oil all over my headers....alot!!! so back went the pcv valve, and no more exsessive crank case pressure...but still using a significant amout of oil....i thought intake gaskets, but then realized it was doing the same thing before i did the swap, it runs fantastic, has 35psi oil pressure at idle hot, and 50+ cruising....i had plans to go with good heads, more cam, etc etc, but now have those plans on hold thinking the rings are pooched....any ideas or input??? Thanks
Dave
Dave
