Ok, here is my issue. I have a 350 sbc that is leaking out of the backside of the intake. I have used black rtv silicone and that has not solved the issue, i have used just Right Stuff and that didn't work. Next go around I decided to lay a bead down allow it to skin and then layed another bead of Right Stuff down and still a leak. The block is a 95-96 one piece rear main gen 1 casting. The block was "0" decked. When I originally assembled the my 383 it had the brodix track 1 heads and brodix single plane intake and no leak but had no bottom end. So i decided to but a edelbrock rpm air gap and ever since then I have had a leak. I have spent my last 3 weekends attempting to reseal it. I have been using the felpro 1206 that brodix recommends. I thought about using the gaskets that edelbrock recommends from their line but side by side everything seems to be indentical except the manufactorer name on them. Any help would be much appreciated
