7.5 I am upgrading my rear to a 3.73 Posi I have everything apart got the pinion gear nut off. Now how do I get old pinion gear out I wanted to ask before I started to pound on it. The U-joint Yoke is still on the pinion gear shaft. Thanks
budss396 said:use a brass punch, Do not re install the nut and hit the gear directly. that is a quick way to run a set of gears.
BUD
