Play in the steering box!
CopperTop
23
I purchased a brand new IROC Z steering box and I have play in it. Can someone point me in the right direction on how to correct it...
If it's new there shouldn't be any play. Check your rag joint on the steering shaft, tie rod ends, idler & pittman arm joints...
CopperTop
23
Every single thing is new. I have the jeep steering shaft in it as well.
Its almost like not having power steering the car drifts in the grooves
In that case, if it's not too late, I'd exchange it. If you can't, back off on the locknut on the top cover. Tighten the slotted screw a little at a time & test drive after each adjustment. If you go too tight, the steering won't return to center properly or the steering will feel tight or "sticky".
CopperTop
23
Hey Tommy thanks for taking a minute to reply. I give up.. lol There is a shop around my job that has been around for years and they specialise in frontends, Im going to let the pros check it out.
