power glide transmission
royce0420
86
Natchez MS
what you guys think about a power glide transmission in a street car car will see a lot of street time it have 410 gear 275 50 15 et street tire my local track is 25 miles away
DOUG213XRJ
4,671
West, MI
On the street its all about gear ratios. I would go with a 700R4 or a th350. What are you running for a transmission now ?
cherp22
2,777
Roxana, IL
Nobody asked about how much power this car makes and what your plans are for it?
SSedan64
948
MACON, GA.
The 700R4 or 2004R built correctly will handle 500HP.
I'd go with a well built 2004R. Easier swap, no 1st-2nd gear spread problems and will handle more power than the 700R4 when built correctly.
If you're serious about Strip use, a Non-Lockup TC is the best choice.
Non-Lock TC is much more efficient than running a Lockup TC when not locked & much lighter. Locking @WOT shifts requires a PI 5-disc lockup clutch TC. Single disc TCC can't handle WOT.
There's only about 150-200rpm difference between Locked & Unlocked TCC while cruising. Many of the PTC brand Non-Locks only have about 3-4% slippage up top. A Lockup TC would be more like 15-20% slip Unlocked. :shock:
prairiehotrodder
1,576
4
Melfort Saskatchewan Canada
I don't think you'll like the powerglide for your application. If you were much lighter and had more gear and a 4000+ convertor and it was mainly a strip car then the glide would be fine.
brian
