ok, im high bidder on a set of cadillac metric calipers with an emergency brake, i have stock calipers up front, would this be the kind of proportioning valve i would want for this setup?
http://www.speedwaymotors.com/Disc-Disc-GM-Proportioning-Valve,13539.html
i would assume so. i am going to try to use the stock e brake pedal assembly already in the car to activate the ebrake. not sure if that will work but i will try that first before going aftermarket.
also does anyone know the part number or point me in the right direction of the rotors i would need? i have a ford bolt pattern in the rear of the car due to my axle spacing. so i would need rotors with that hole pattern drilled into them, im looking at this setup from dca racing....
http://dcaracing.com/cat_9inrearend_1.html
the dca disc brake kit on the bottom of the page.
thanks for the input guys, the car wont be rolling down the road anytime soon, just trying to put the pieces together.
