rear narrowing?
boostinmalibu
756
joplin missouri
how much can you narrow the housing before worrying about the factory lower mount? i have a lead on some 15x10s alumastars with 3" backspacing for cheap.
gman415
883
Chattanooga
JMHO, By the time,and money, you spend on the houseing and axles you could buy wheels. And then you'll run in to tire to shock/LCA clearance issues.
Barry 85 SS
662
Newport News, Va
To keep the tire inside the wheel well with a 10" rim you would probably have to do a frame notch too. What rear end do you have. If you narrow it and use Ford style housing ends you can eliminate the C clips too. With a frame notch you would want to shorten the rear about 2" per side. You would need to do some careful measuring to be sure.
bracketchev1221
1,111
Mountville Pa
This is my thought as well.
boostinmalibu
756
joplin missouri
well i dont have a rear ordered yet, but this post is kinda no good now, i found some 15x10s w/ 5.5 backspacing
the car is getting a max notch and mini tub for a 295 radial
10secBu
4,284
Westminster, MD
I have a new TRZ housing in which we moved the LCA mounts 1 to 1 1/2" in from stock, plus the mounts are narrower than stock anyway.
My old rear was 59 1/2" wheel to wheel, the new rear will be 52" wheel to wheel. That's 7" narrower than what it was, 6" narrower than a stock G-body rear.
Rear wheels are 10" wide with a 2 7/8" back space. max frame notch.
