rebuild front suspension.
1981Regal
1,274
Cincinnati, Ohio
Used to be RockAuto.com was pretty reasonable on moog suspension parts. Not sure if there is a cheaper place these days or not. I'd check them out and compare price vs local.
The Roudy #3 4 ever
227
plummer idaho
When I did mine a couple of years ago, got a kit from Speedway. Part # 917-3236, $159.99. Comes with ball joints, inner and outer tie rod ends, tie rod sleeves, center link and idler arm. 1 easy kit.
1981Regal
1,274
Cincinnati, Ohio
I'm sure those are the cheapest economy replacement parts available. That's fine depending on what your needs might be. Just know that is roughly 13.33 for each part of the 12 part kit.
1981Regal
1,274
Cincinnati, Ohio
Here is the link for the Speedway kit.
4,654
31
If there is an option to upgrade to polyurethane boots, do it; if not get polyurethane boots separately. The PST kit I installed in the mid 90s had rubber boots and the tie rod end boots split after a very short time.
bustedknuckles
577
johnson city, tennessee
Thanks for the information. I would like to order everything I need at one time. So any info on control arm bushings? I found the rear on the Speedway site but not the front. Also couldn't find the body mounts. In another post someone mentioned to get the body mounts for a Regal due to having additional mount? Any help is greatly appreciated. Thanks everyone
shvrolay
~JM~
99
shvrolay
