S10 booster + Trans Am master cylinder mod and install
Malibutomi
462
Hungary
www.hebonline.hu
So i bought a 4 wheel disc 81 TA master cylinder for the brake upgrade, but it didnt fit on my booster, so i got an S10 booster from a friend, which is the same as my old one, except that it works with the bigger MC. But it had a longer brake pedal rod, so i had to mod it.
Boosters face, S10 on the left, malibu on right.
The S10 had much longer rod
So i bought these bolts, to correct it:
Cut it, and tadaaa
Master cylinder on its place:
And finally the 12" upgrade complete:
Tomorrow ill bleed it, and try it!! Cant wait.
In fact it feels much stiffer than the old one even now...i like it :)
Malibutomi
462
Hungary
www.hebonline.hu
Actually its an eye bolt, and an extension nut. I cut the threads on the rod, and bolted together, so now its adjustable :)
I could get a p/n but dont think you can use it...look my location..:)
The rod diameter is 3/8", so you can get this size eye bolt i think.
388bu
3,228
Huntley, il
www.shiftn6.com
Ok cool. Thanks.
