SBC/BBC solid motor mounts?
Brian79
383
Wataga, IL
Are the sbc motor mount the same as a bbc? I sold my 79 Malibu to my buddy. I ran a 355 and he is going to run a 454. I had solid motor mounts on the car and was wondering if I leave the mounts on the car will they bolt up to his 454? If not I will keep them on the 355 for my next build.
Malibuwagon80
1,255
I have Moroso steel mounts on mine {461} and from what I understand they are lower than a stock mount. I hear you can use a small block frame mount but I'm not sure one the engine side of the deal. Why not just get a jegs catalog out and check the part no's on big block and small block mounts?
bracketchev1221
1,111
Mountville Pa
It all depends on engine height. You can put a big block on a small block mount, but it may cause oil pan clearance issues. My Chevelle ran a small block and big block on the same mounts.
