serpentine question
dirtymax6489
22
Battle Creek MI
Gen 4 454.....direction for belt system. Should i get a serp system off a 90's chevy pickup and buy the adaptor brakets or try to find a big block serp system of a 90's chevy? Only running crank,alt,and water pump. Or should i stick with a v belt?
1980PontiacWagon
686
Northern Virginia
Your best bet is to find a set up off a big block if you really want it...I've never seen someone use those conversion brackets, so I am a little curious to find out if they work..And I think if your only running water pump and alternator it might be a hassle to find the needed idle pulleys...I would stick with V-belt with your set up...but if you do find a big block serp. set up I and probably other memebers would be interested if its for a good price.
