SHOCK HELP
MYMONTECARLO
50
CINCINNATI,OHIO
Hey guys, I wanted to correct IC and to level lca. I installed afco's springs,12" 150. I bought afco's dbl. adj. shocks. part # 3870r-1. that shock has a 7" stroke. When I installed them,they are bottom out w/ no shaft showing. Afco said I could run a 5" stroke shock. Should i run 7" shock mounted in stock mount just lowering mounting point or mount them straight up like true coil-over style,or just go w/5" stroke shock, thanks for any advice.
