south side bars mounting brackets
bad70nova
54
Leitchfield, KY
I am looking for the south side brackets that mount inside the shock mounts for a 78 malibu with a 10 bolt 8.5.
I know someone out there knows what i am talking about i just need the two plates that get bolted where the lower control arms were removed from then you bolt these plates in then you weld them to the housing. I have a set bu am swapping out rear's and dont want to try and cut these old ones off as they are welded quite heavely. Thanks for any help.
