stall advice
rsh4364
744
greensprings,ohio
T/C stall advice,79 Malibu lightened a bit,355 sbc,comp.cams 274 extreme cam,ed.alum.heads airgap rpm intake,1 inch supersucker,demon 750 vac.sec.,th350 trans,430 gears 28 inch rear tire,gearvendors under/overdrive unit .78 od, estimated rpm at 60 2400..98 percent steet driven,prob. hit with 100 shot nos occationally, any advice ?
Bad Medicine Racing
431
Grove Oak, AL
Call PTC. 256-383-6868. That's what they do.
2800 - 3200 RPM would be ideal for your combination. We offer member discounts if you would like to order a converter built specifically for your combination. Let me know if I can help you out.
rsh4364
744
greensprings,ohio
Thanks Pete,This is why I buy your stuff,you are here.Thinking gonna go with your gm30,but what is difference between your gm30 and gm30hd,I understand hd is heavyduty,but i will only be running 550 hp or lower..For now anyways...
Our "HD" converters feature additional brazing of the turbine and impeller fins, a heat treated steel turbine spline, and oversize rollers in the sprag so that the sprag can withstand higher shock loads and additional torque output from the engine. I recommend the "HD" series for any street or mild street/strip combination exceeding 500 flywheel horsepower, or any street or mild street/strip combination using a small power adder such as a nitrous system up to 175 horsepower, or a supercharger/turbocharger up to 7 - 8 PSI of boost.
For combinations exceeding 650 flywheel horsepower, or using a transbrake, I recommend using one of our Pro Series custom built torque converters. I have 9", 10", and 10.5" custom built converters starting at $729.95, and an MR.com member discount is available on that price.
