Stock suspension tricks high HP cars
mwudel
Member
Dec 2, 2007
6
Tea South Dakota
Ok are any of you guys that are running stock susp doing anything with the engine location up or down. This is a small tire turbo car that will make 1300 HP plus with a glide and i am thinking 3.70 is gear. Car works very well at the old power level but just want a little help from the fast guys on the "insider" tricks front, rear and engine location. looking to run very low 8's on a 295 DR or 29x10 slick.
Thanks
Mark
DB
363
Alabama
Stock engine location here. Plenty heavy on the nose to with the turbo and intercooler. It's all in the converter, tire, gear and instant center. You gotta hit the tire and get after it. There's no easy answer because every car is different. I got after mine until it started standing up then limited the front travel. I had stock front springs, junky Comp engineering shocks on the front and ran 5.0's. Now I have the TRZ uppers and lowers to save weight and some better shocks. You have to play with the ride height to get the instant center where you need it to plant the tire or you have to have some adjustments on the rear housing. TRZ is working on a bolt in 9" rear to allow these adjustments.
mwudel
Member
Dec 2, 2007
6
Tea South Dakota
seems like you have your car working well!! What kind of HP do you think your making.
My ride hieght is fairly low have not looked at the lower bar angle in a long time becasue it worked well and i never messed with it. This is just a whole new level of power for me with the little tire. Have been in the sevens on a 14x32 in a chassis car but like i said whole different ball game here. Thanks for the input i am sure i will need all the help i can get.
Thanks
Mark
DB
363
Alabama
I'm making between 1700-1800hp and I run on a 325/50 radial. Went 1.26 60' and 4.96 at 149. It's been a best of 1.23 60'.
What rear are you using? With the 8.5's you need the ride height really low to move the instant center down and to the rear. Moving the lower arm down on the rear housing will move the instant center back but it also moves it up and can hit the tire too hard. You'll know this if the car has to much seperation on launch.
You have to find that point where you get a little seperation but not hit the tire too hard. Once you get it to move 10-15 feet you gotta pour the power on to keep the weight transfered. If the nose settles and then you loose traction, you need more power or you'll have to lower the launch rpm. You have to bring the power on quickly. If the nose ever settles it will unload the tires. Keeping it working from track to track is the hard part. Too much power and it spins at the hit. Not enough power and you spin 30 feet out. But all this is no good if the suspension is not set up properly.
mwudel
Member
Dec 2, 2007
6
Tea South Dakota
9 inch rear have not swaped the gear yet not real sure what to go with. Will be a PTC converter i think, have heard nothing but good about them. Have the 7531 box and either the AMS 1000 or the prologger for boost control. Turbo is a precisssion 106 so i will have all the boost that this motor will ever handle (good parts just a stock block). Just making the swith so the new motor will come out after i get a handle on all the fuel and electronics. Then we can really poor the boost to it.
Thanks
mark
DB
363
Alabama
I run a 3.70 gear. The AMS 1000 is the way to go, no doubt about that.
I'll PM you my cell #. When you get ready for a converter call me. I'm PTC's largest distributor and will get you what you need. I've tested at least 5 different converters for them in my car.
malibulvr
1,929
Pensacola, Fl. 32526
Do you have a pic that you could post of your car and the way it sits with the 325 drag radials.
slimbo
Staff member
May 21, 2007
4,223
www.yellowbullet.com
thats a bad machine right there...
cutlass389
684
NC
LOVE that third pic! Tires are workin' and no g-body twist. EXCELLENT! When I grow up blah, blah, blah.
KEVINS
It's interesting to watch people learn over time what is required as their car gets faster. Most people think it's all in the suspension and that all they have to do is hit that right combination of settings but as you mentioned as the car gets faster they need to start playing with motor, transmission, converter, etc and to learn what it takes to keep it hooked.
Kewl Ride!
ks
87montess
169
PHILLY
NICE RIDE DB what rim size is on the back and how much did u take out of the frame i would love to get 325-50 on my monte ss
DB
363
Alabama
Kewl Ride!
ks
Thanks Kevin. I have spoken to you before, probably 3 years ago about the instant center stuff. Even then it was hard to imagine just changing an angle of a bar by ride height adjustments could effect traction like it does. It took me at least a year of studying the suspension, watching my launch videos and moving stuff around to get a handle on it. People will look under my car and think there's no way this 9 second suspension would go 1.23 on a 325 radial turbo car at 3500#. It still isn't ideal, but it works. But the power management from the engine through the converter played just as large a role as the suspension. The converter was the missing piece to my puzzle.
DB
363
Alabama
15x11 with 6 inch bs. I took a lot of the frame away. I left about 1/8 of the C channel of the frame in place and I put 1/8 plate back in place to box the frame back in. It's barely enough for the 325. If I do it again, I'll take it back to the rear rail.
DB
363
Alabama
ILLEGAL REGAL™ said:
Hey Dusty... do you fell that air dam helps any?
I can't say that it does for the mph or et but it sure makes the Regal look better. It don't have that Bart Simpson overbite anymore :mrgreen:
DB
363
Alabama
TRZ will have a new Fab 9" rear end coming down the pipe to help guys with these instant center issues. I've been fortunate enough to get to race with Todd and Mike and can say that what we all have learned and tested in the last year will now be available through TRZ to push all g-bodies to another level. Just the testing from the last 2 track outings has made a ton of progress.
