Swapping a 305 for a 350
slpfeife9651
32
Rochester, MN
I'm probably in over my head here, but I bought a 350 bored out .030 over with a mild cam and decent heads, and now I want to swap it out for the stock 305 in my 1979 malibu. I am under the impression that this should be an easy enough swap, but I've never actually pulled a motor or put one in either. I had a buddy of mine that was gonna help me, but he lost his job and moved away.
So I have been looking around our site here, but haven't found anything as far as pictures, or a video and was wondering if anyone knew the whereabouts and could send me a link or something. Also and tips or advice would be much appreciated.
Thanks Guys, and let me know if anyone needs a 305!
TURNA
6,028
Socialist NY
It is a direct swap everything is the same.
May want to put your location in your profile.
You never know, you may have a member from here near you that could lend a hand.
lurchsmalibu
3,774
Lakeland, Florida
X2....have you tore into it yet?
slpfeife9651
32
Rochester, MN
Not yet, still waiting for it to warm up a bit so I can organize my garage! I'll let you guys know how it goes...
Jaypaso
166
Detroit, MI
location?
lurchsmalibu
3,774
Lakeland, Florida
Tag on the avatar pic looks to be Illinois right? :-k
chevybowtie
Member
Feb 24, 2011
7
It really is easy. More or less all you'll have to do it:
remove engine mount bolts
remove transmission bellhousing bolts
remove torque converter bolts
remove wire to starter
unbolt exhaust manifolds
remove fuel line (if it's a q-jet its just one line)
remove throttle linkage
remove brake booster vacumn line
remove coolant hoses
unbolt a few electronic fittings here and there
really, that's prett much it. get a haynes manual...it's a weekend job.
malzer
212
Gettysburg Pennsylvania
1) Disconnect negative battery terminal, sounds silly but should be the first thing done.
