That is the exact style of tach setup I was looking for when I found the one I did. Yours look like they were in nice shape, too! Thanks for the info-I had three wires...a pink w/blk stripe (IGN. +12V), a black wire wiht a slide on ground clamp and a tan wire for the dist. tach terminal. But, on the back of the cluster next to the tach plug in it says run at 1/2 engine speed only so I assume this cluster came from a diesel truck....i am now wondering if I can simply wire a resistor inline to the dist. lead or use a tach filter from say, a Monte SS to do this. I can't find a diagram showing a filter but I also am unsure what resistance rating to put it at...I may just buy an assortment of resistors and see what happens. I started the truck and @ idle the tach was reading 1600 RPM's...lol. I am still going to try and find a different tach assembly even though after cleaning this one, I like the way it looks a lot! Areally clean assembly sells for roughly 100-125 on Ebay but they are all dirty to an extent so it's a toss-up...after all, these tach clusters are getting pretty damn old...mine works great save for the tach jumping too high.
