TH-200 to TH-350 Swap in 79 Malibu
ricnic1002
257
Naperville, Il.
Hey guys,
I just ordered a 350 trans and a converter for it. Does anyone know if my collum shift linkange from the TH-200 will bolt up to the Th-350? Also, will the trans dipstick swap over? I understand as far as installing, it is a direct bolt up, same drive shaft length. My concern is the shift linkage. (Until I get a floor shifter.) Any input would be great.
Rich
DOUG213XRJ
4,671
West, MI
X2 Dip stick and linkage should be fine. You will need a vacuum source, The TH350 has a vacuum modulator and the TH200 did not. T into the intake right behind the carburetor. Doug
