have a couple questions first will explain few things i am novice in this area i have a ron sessions book as a guide ,,,,,, i have 2 trannys one has broken bolt holes on bell housing so looking to swap the internals to another good case i have,,,,,,,,,,,,,,,, below is 2 pics of the low//reverse piston the broken case one has the holes in the piston and the good case 1 doesnt have holes i was thinking of not swapping the low//reverse pistons because i dont have the compressor tool but wondered if it could become an issue ??? question 2 in the good case when i was trying to remove the low//reverse roller clutch i had to push the anti-clunk spring clockwise to spin the low//reverse roller clutch clockwise so it wouldn't be in grooves for removal the book says if its stuck to spin it clockwise due to worn case splines now i am wondering if its a good useable case to sum it up the anti-clunk spring was pushing roller clutch into the groves preventing the roller clutch to be removed .... thanks for everyones input
