time for 78 to go under the knife 6.0 lq4
JRodS79
1,567
kansas city mo
K, so i put a feeler out to my local LKQ salesman in Topeka for a 6.0. i told him i wanted one complete
i was talking with him the other day on some ZQ8 wheels and he told me he had a motor i couldnt pass up
05 LQ4 50k mi 6.0 top to bottom L to R with maf, gas pedal assm, and fuel pump for 1200
i told him SOLD
now i got to figure out how to mate this thing to a 4sp till the funds come for the t56
pics as soon as the blue and white truck drops off my present \:D/
388bu
3,228
Huntley, il
www.shiftn6.com
Good deal!
Bolting the 4-speed to it shouldnt be too bad. If you are running hydraulics, then it will be really easy:
Re-use your old bellhousing and get the McCleod "adapter" flywheel. http://store.summitracing.com/partdetail.asp?part=MCL-460535&autoview=sku
If you have mechanical linkage, then you will need to figure out the zbar mount obviously...I cant offer much advice there.
JRodS79
1,567
kansas city mo
OUCH!! that link stung a little
you think ill need anything other than that??
adapter mounts, different manifolds/headers since the truck manifolds don't clear, a different bellhousing because the one on Summit is 168-tooth and the G-Body bellhousing is 153-tooth (aftermarket = a few hundred more $$$), the z-bar may or may not clear the exhaust on the LS motor, so you may have to go hydraulic ($30-$50+ for a used master cyl, John Bzdel pedal, reservoir, slave cylinder, more $$$). You'll probably spend another $1,000+ easy doing the swap.
JRodS79
1,567
kansas city mo
i told the wife an extra 2 large to get it into the car.
think i may hold out for a 6spd core. one of our new tecs is fresh out the dealer and manny trannys are his specialty
im all about the cheap. (arnt we all)
going to buy the shoenfelds and mod them to fit
so on and so on
has anyone taken a stock g sender or a fi g body sender and make it work with a stock pump?
MalibuRacing
3,465
www.maliburacing.com
Roller406bu is running the full length Pacesetter headers for a F-body and said they fit fine. The show them for $279 (painted) on the pacesetter web site.
JRodS79
1,567
kansas city mo
that sounds like a better plan than the shoens
