Had my q-jet rebuilt (big mistake) by a local speed shop. Ever since its been back on the car the idle is going up and down. Started messing with the idle screw on the carb but idle never got right. idle would go so low at times it would cut off. Well i decided to stick my timing light on the sucker to see if I needed to adjust it. While i had the light on it as the idle went up and down...the timing started going up and down as well.
Could the timing going up and down be caused by the carb being screwed up or am I looking at a potential timing chain issue? There is no spit back in the carb while it trying to idle but if you try to give it and gas it wants to bog pretty bad and then it will rev. Any one have any ideas or direction? I appreciate any help that is given. ](*,)
