Tire Wheel Combo ? ? ? ?
sleeper5976
69
Ok guys Im putting an 81 Malibu together and need some help. Car is apart right now doing a frame notch, fender roll, bfh to fenderwell lip, qa1 coilover conversion, and trz arb install, iceman uppers and lowers, tnt braces. Rearend is a 8.5 10 bolt A Body rear (measures approx. 55 3/8). My question is how much tire can I put under it (car is guna sit low) and suggestions on the back spacing? Thanks
Forgot to mention the frame notch is not a full or max notch, notched 1 inch which is just on the other side of the factory weld line.
Would like to run MT DR 295/55/15 if possible, MT suggests a 9.5 in. rim, could this tire work on a 15x9 or would I need 15x10 and would any of this work out
Pictures to go with your comments or combo's appreciated
