torque converter ?
c_unitproductions
35
haines city,fl
ive got a 406 sbc flat top 2 valve relief(eye brow) 5.7 aftermarket i-beam rods steel cast 3.75 crank, 2.02 (292 castings) port alot (bought them used for 100) dual valve springs for roller cam .584 .596 lift solid roller cam and an open plain victor jr intake 750 holley double pumper i have a summit 32-3500 stall. really havent got any good numbers trying to get the fuel right. leaning real bad should be out this week with more fuel. going to put a different top end. dart pro 1 fully race port and flowed(race heads inc. palm coast,fl) custom grind cam .654 .645 lift will look for the cam card tomorrow for exact info and a fully race ported intake team g(3/4 raised plenum). just trying to get a good stall to work with this set-up in a full weight(not exactly sure) 87 monte ss. will see some street driving but more track. want it to work both ways. ive got a tci 5000 but i know that should be way too much?! any info would be grateful thanks!!!!
cutlass389
684
NC
Need more info and you need to be honest with yourself about intended usage. EVERYBODY says "it'll be a street/strip car". How long will it be before the new setup is put in place? Need the rear gear and intake duration #. Tentatively, I would think that the 3400 would be fine with stock heads, and 5000 with aftermarket heads and a solid cam will work out but it won't be a street car anymore though.
purple barney
576
Raleigh NC
x2 every custom converter comp will ask if you had your motor dynoed, they will select the stall that is in your hp and tq curve (other factors vehicle weight tire size....) with lift number like that your duaration will also be high so the cam will kick in higher in rpms = large stall= less street
c_unitproductions
35
haines city,fl
i couldnt find my cam card so i had to get on my old computer that has my desktop dyno. the intake duration is 264. not sure on what the vehicle weight is gonna be exactly. the tire size will probably be a 28 inch at most by 10.50. gear ratio depends on if it will be streetible. still not exactly for sure that this is gonna happen thats why im asking. this was going to go into the car i built my dad and he is never home he drives a truck so at most 3 miles to his job from home. i live about the same from my job. not trying to make it a daily driver just to work every once in a while and there is a car show in my town and in the next lil town about 10 minutes away. back to the gears i have a set of 4.11 and a set of 4.86. thanks!
cutlass389
684
NC
264? Is that advertised or @ .050?
cutlass389
684
NC
264 @ .050 is big! Even for a 406. Other than short jaunts, that probably isn't gonna' be streetable.
