Hey guys I put a th350 in my 86 cutlass and i knew i had to adjust the linkage. i adjusted the linkage in drive and the car seemed not to want to "lock" in park....then i adjusted the linkage in park but when i went to shift into drive the car went into 2nd gear.....so i have to put the indicator on the gauge cluster between neutral and drive which bothers me because i think ill end up burning my steels/clutches....the car drives and shifts fine like that but im pretty sure the transmission isnt all the way in drive because i can tell a difference between the shifts when i change gears.....for example ill drive it to the store park my car and when i come back out i shift back between neutral and drive but i might not get into the same spot as before and it might shift harder or softer than before......what can i do to correct this??? another question i have is about my speedometer along with my th350 i swapped my stock rear end to another stock rear end out of a monte ss which i was told had a 3.73 rear gear...and i have noticed that my speedometer is around 20 mph off...i have the stock rims and tires from the cutlass on it and i think the total diameter is around 26 inches....anyone know what speedometer gears would correct my speedometer?
Thanks for any help
Thanks for any help
