Anyone one what ball joints TRZ uses in there lower arms?Im gonna be re powder coating mine and figured I may as well replace them at the same time.I ran out of time today before I could call them.
It's a stock replacement ball joint, just with an internal boot instead of a loose external boot. Some parts stores may have them, but make sure the boot is tight to the ball joint and attached with some kind of metal spring clip. If you get the loose boot, the grease will just come out of the boot and leak all over the place. We have them here if you can't find them, they are $23 each (K6145T).
